DYMO® LetraTag®
Os rotuladores DYMO® LetraTag® foram projetados para uso doméstico ou no escritório. Conheça os modelos portáteis LetraTag® 200B, LetraTag® 100H, LetraTag® 100T e LetraTag® 100H Plus
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 87
Ao todo: 896
2 comentários
Please advice, I disassembled the machine, and found a loose spring. I found out that the spring is used to retract the cutter after cutting. But I can't figure out the correct placement of the spring. Does anyone know? It is the handheld version.
Lemonoius - Responder Compartilhar
Now I know. Disassemble completely the cutter handle and remove the white part. Then remove the circuit board part from the tape holder. Then the cutter mechanism will come out, and the spring belongs inside the part the blade is fastened to. Use this video to disassemble. https://www.youtube.com/watch?v=UoRt52zM...
