Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Battery won’t charge
The laptop will not turn on or charge when plugged in
Faulty power adapter
The power adapter is located on the charging cord. If the light on the power adapter is not on, check to make sure it is plugged in. If the cord is plugged in and the light is still not lit, you may need to replace the adapter.
Faulty battery
If the battery does not hold a charge, but the power adapter is not faulty, your battery is faulty and needs to be replaced. To replace the battery, see the replacement guide.
Laptop fan failure
Fan will not turn on in order to cool overheated laptop, or is blowing hot air.
Dust or particle build up
If dust or other particles have built up on the fan, it will not turn. Simply blow air (preferably through a compressed air can) through the vents to clear the build up.
Heat sensor is off
If the problem isn’t a build up of dust or other particles, the heat sensor may be off. To correct this, perform a hard reset by shutting down and removing all power to the laptop. Booting the laptop back up should reset the sensor setting.
The CPU fan is damaged
If the above solutions are not effective, the device probably has a damaged CPU (Central Processing Unit) fan that needs to be replaced. To replace the fan, see the replacement guide.
Keyboard Not Responding
One or multiple keys on the keyboard is not responding or is broken.
One or more keys is stuck in place
Debris can sometimes lodge a key into place. Remove the key, using the replacement guide and ensure that there is no debris preventing it from moving.
Missing or broken key
If you are missing a key or there is no debris preventing the key from moving, you may need to replace a single key.
Faulty keyboard
If the entire keyboard is not responding, it likely needs to be replaced.
Track pad not responding
The laptop’s track pad mouse is not responding to touch.
Track pad is disabled via FN key
Press FN+F9 to correct a disabled track pad.
Track pad driver failure
If your track pad is not disabled, your laptop may need an updated driver. You can update your driver by finding the device manager in your laptop’s settings, then searching for a driver update.
Track pad is disabled in the motherboard BIOS
Turn on the track pad in the motherboard BIOS (Basic Input/Output System).
Faulty track pad
If the above solutions do not fix the problem, the track pad needs to be replaced. That can be done using the replacement guide, found here.
Speakers not playing
Audio does not play through the internal speakers
Volume is not up or it is off
The volume on your laptop is turned off or too low to be audible. Turn the volume up by pressing F3 until audio plays at the desired volume.
New driver required
Check for an update on your driver using your laptop’s device manager and searching for an update.
Speaker not detected
If your laptop does not detect a speaker or the above solutions do not solve the issue, perform a hard reset. This can be done by powering down your computer, removing power sources, and then restarting the laptop.
Faulty speaker
If the above solutions do not resolve the problem, the laptop likely has a faulty speaker. It can be replaced using this replacement guide.
3 comentários
I NEED HELP, FOR MY ASUS TUF FX705G,
IF WIFI CARD IS PRESENT, LAPTOP CANNOT DISPLAY.
IF I REMOVE WIFI CARD, LAPTOP IS WOKING PROPERLY. ANY SUGGESTION PLEASE..
Procy Dongiapon - Responder
I’m having a problem with my computer gets too hot. The plug will unplug itself plug itself back in and then unplug itself again over and over and over again what the Hells going on
mighty mince - Responder
I have the same laptop and its throwing so many issues, its been only one year and too many issues occurring, display flickering when charging, settings not opening or opening after a long waiting, speakers not working, WIFI option disappearing, i had to buy external WIFI for the same. I havent even installed any big apps then also so many issues, its like i have wasted my hard earned money on this junk box. seems like Asus is not providing good products. my brother bought Dell gaming and its cheaper and better than this one.
Shivani Loht - Responder
