Ir para o conteúdo principal
Asus TUF Gaming FX705G Fan Replacement
O que você precisa
  1. Asus TUF Gaming FX705G Fan Replacement, Back Cover: passo 1, imagem 1 %32 Asus TUF Gaming FX705G Fan Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Fan Replacement: passo 2, imagem 1 %32 Asus TUF Gaming FX705G Fan Replacement: passo 2, imagem 2 %32
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Fan Replacement, Battery: passo 3, imagem 1 %32 Asus TUF Gaming FX705G Fan Replacement, Battery: passo 3, imagem 2 %32
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Fan Replacement: passo 4, imagem 1 %32 Asus TUF Gaming FX705G Fan Replacement: passo 4, imagem 2 %32
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Fan Replacement, Fan: passo 5, imagem 1 %32 Asus TUF Gaming FX705G Fan Replacement, Fan: passo 5, imagem 2 %32
    • Remove the five Phillips #00 screws from the fan casings.
    • The left fan has three screws and the right fan has two screws.
  6. Asus TUF Gaming FX705G Fan Replacement: passo 6, imagem 1 %32 Asus TUF Gaming FX705G Fan Replacement: passo 6, imagem 2 %32 Asus TUF Gaming FX705G Fan Replacement: passo 6, imagem 3 %32
    • Unplug the cables that connect the fan to the motherboard.
  7. Asus TUF Gaming FX705G Fan Replacement: passo 7, imagem 1 %32 Asus TUF Gaming FX705G Fan Replacement: passo 7, imagem 2 %32 Asus TUF Gaming FX705G Fan Replacement: passo 7, imagem 3 %32
    • Lift the motherboard to unclip the housing clip on the back of the fan.
    • Remove the fan.
Conclusão
15 outras pessoas executaram este guia.
3 comentários
A bit nerve-racking, but got the new CPU fan installed, seems to be working fine according to armory crate. I did note that the CPU fan plug was quite stiff but I did manage to carefully wiggle it out. Anyways found your instructions very helpful especially the pics.
Thank You.
1857classic - Responder
Is it possible to change the cpu an gpu I'm a noob for sure thanks
Like to change them to make it a better pc might not be able to FX705DY
Christopher Hall - Responder
This was very helpful. Thank you
Sue Olmos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 130
Duração total: 15,461
