Ferramentas utilizadas neste teardown
Introdução
Apple has quietly introduced an updated version of the iPod Touch 5th Generation 16 GB. What exactly is Apple trying to sneak past us? We're about to find out. Join us as we explore the newest addition to the iPod Touch family. Ladies and gentlemen, we present the iPod Touch 5th Generation 16 GB 2014 teardown.
This teardown train stops for no one! Friend us on Facebook, trade tweets with us on Twitter, and get touchy feely on our Instagram.
The new and improved iPod Touch 5th Generation 16 GB economy model now features a 5-megapixel iSight camera, bringing it up to par with its 32 and 64 GB brethren.
Let's take a look at the technical specifications:
4-inch (diagonal) widescreen Retina display with Multi-Touch IPS technology
802.11a/b/g/n Wi-Fi (802.11n 2.4GHz and 5GHz) + Bluetooth 4.0
5-megapixel, 1080p iSight camera with LED flash and a ƒ/2.4 aperture FaceTime 1.2 MP HD camera capable of capturing HD video (720p) up to 30 fps
New iPod touch loop
Three-axis gyro + accelerometer
16 GB storage capacity
The iPod Touch 5th Gen 16 GB 2014 gains the wrist-strap peg previously reserved for the upper echelons of the Touch line—though you'll have to shell out some more dough for the strap itself, which is sold separately.
We spy a revised model number tattooed on the back: A1421.
Wait just a minute—we've seen that number before, on the similar, but higher-end iPod Touch 5th Generation variants.
The first major change is unearthed: The headphone jack no longer has the bit of tape found in its beefier-storaged cousins.
That makes your repair one step easier, and probably saves Apple billionths and billionths of pennies!
Then again, maybe they just forgot the tape in this unit...
Commence separation! Here we can see the wonderful mess of guts that have been stuffed inside this iPod.
Since this is the same device, we won't announce it as news—but Apple certainly likes to play the "how many components can we cram onto a single cable" game in their iPods.
This reigning champion rests easy, assured of its claim to the title. While the rest of us plot its demise.
Apple probably chose this humble device to introduce a revolutionary new camera, said no one.
Actually, this looks very much like the camera we found in the other A1421 models. It packs a five-element lens with a hybrid IR filter and an ƒ/2.4 aperture. It's able to capture 5 MP images or 1080p (full HD) video at 30 FPS.
What sorts of integrated chips will we find on the logic board? Let's see:
Apple A5 dual-core processor, with 4 Gb (512 MB) of Elpida Mobile DDR2 RAM, denoted by the B4064B3PM silkscreen label
Toshiba THGBX3G7D2KLA0C 128 Gb (16 GB) NAND flash
Apple 338S1064-B1 dialog power management IC (similar to the Apple 338S1131)
Murata 339S0171 Wi-Fi module
Broadcom BCM5976 touchscreen controller
338S1146 Apple/Cirrus Logic audio codec
STMicroelectronics AGD4 2336 L84DC low-power, three-axis gyroscope
Integrated chips galore! Let's check out the rest of the smorgasbord:
Texas Instruments 343S0628 touchscreen controller
STMicroelectronics 8406 DSH 08BIY
NXP Semiconductors 1608A1 display interface controller
Hiding between the Lightning connector and headphone jack, we (again) find:
Apple 338S1077 Cirrus Logic audio codec
(Still) no surprises here, the iPod Touch 5th Generation 16 GB 2014 Repairability score: 3 out of 10 (10 is easiest to repair).
While very difficult, opening the case and replacing components is not impossible.
The battery is flanked by notches that make prying it out of the rear case fairly easy.
Many components are soldered together, requiring either a very difficult or a very expensive repair if any one part breaks.
There are no external screws. Instead, a combo of clips and adhesive makes it difficult to open the case.
Ribbon cables connected to the logic board run over the top and connect on the bottom, making it difficult to remove the board or disconnect the cables.
3 comentários
These teardowns are so interesting! Thanks! ☺
these things are really . . . empty . . . how can they fit a whole ipod on such a small board??? That is so amazing . . . Technology is AWESOME!!!
