Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Sony MDR-1000X, use o nosso manual de serviço.
  1. Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove the Foam Cup: passo 1, imagem 1 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove the Foam Cup: passo 1, imagem 2 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove the Foam Cup: passo 1, imagem 3 %32
    • Use a spudger to pry the six notches holding the foam cup from the headphone.
    • There are three notches at the top and three at the bottom.
  2. Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove 4 Screws: passo 2, imagem 1 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove 4 Screws: passo 2, imagem 2 %32
    • After removing the ear foam cup, you will see a piece of circular foam. Gently lift the top to locate 2 screws and lift the bottom to locate another 2 screws.
    • Remove all four screws.
  3. Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove Outer Cover: passo 3, imagem 1 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove Outer Cover: passo 3, imagem 2 %32
    • Use a spudger to go around the outer cover to remove it. *Note there are cables still connected to the cover thus do not take apart with force.
  4. Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove 3 Screws: passo 4, imagem 1 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove 3 Screws: passo 4, imagem 2 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove 3 Screws: passo 4, imagem 3 %32
    • Locate 3 screws around the lower ring. Remove all 3 of them and gently remove the ring.
  5. Sony MDR-1000X Noise Cancelling Headphone Teardown, Access the Power / NC / Ambient Buttons: passo 5, imagem 1 %32
    • You will be able to pop out the three buttons! To put back the items, reverse the steps. :)
  6. Sony MDR-1000X Noise Cancelling Headphone Teardown, Access the battery compartment: passo 6, imagem 1 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Access the battery compartment: passo 6, imagem 2 %32
    • To access the battery compartment, repeat Step 1 - 3 to open up the other side of the headphone.
    • The battery on mine is a model: Sony SP73, 3.7V, 1200mah Li-ion battery. The battery is held on by adhesive.
  7. Sony MDR-1000X Noise Cancelling Headphone Teardown, Disconnect The Earcup: passo 7, imagem 1 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Disconnect The Earcup: passo 7, imagem 2 %32
    • Gently lift the white flap on one side of the ribbon cable connecting the ear cup to the main board and gently slide the cable out. Rock it back and forth a little if needed.
  8. Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove The 4 Screws Holding Down The Beige Mount: passo 8, imagem 1 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove The 4 Screws Holding Down The Beige Mount: passo 8, imagem 2 %32
    • Remove the tape if needed, and then carefully remove the 4 Screws Holding Down The Beige Battery Mount, and the silver screw holding down the main board.
    • Caution!!! The battery mount is wired to cables on the back side of it, do not remove it completely, we just need to gently move the circuit board below.
  9. Sony MDR-1000X Noise Cancelling Headphone Teardown, Lift The Battery Mount And Circuit Board And Remove The Port Cover: passo 9, imagem 1 %32 Sony MDR-1000X Noise Cancelling Headphone Teardown, Lift The Battery Mount And Circuit Board And Remove The Port Cover: passo 9, imagem 2 %32
    • Gently shift the battery mount and main board without completely removing them to access the three screws holding in place the charging port cover.
    • Slide the charging port cover out to reveal the charging port board.
  10. Sony MDR-1000X Noise Cancelling Headphone Teardown, Remove The Charging Port Board: passo 10, imagem 1 %32
    • Remove the single screw holding the charging port in place and slide the ribbon cable out from the main board to detach it.
    • Note that this ribbon cable has no white latch, it's held in place by the tension of the cable and the case itself so don't try to pry anything up.
dinoofsg
Membro desde: 02/02/13
248 Reputação
Autoria de 1 guia
38 comentários
Nice thank you. Maybe replace the German headlines (Einleitung, Schritt 1 so on ) with the English translation. ;-) Do you know where to get replacements for the foam cup?
Tim - Responder
Hi Tim, you could try aliexpress.com to see if they have it. This product is pretty new thus might be difficult to find.
dinoofsg -
Thank you for this teardown. I have been searching about if battery replacement is easy to do at home - a thing really important for me when buying new electronics. I haven't found any articles about this yet, did you happen to see if that would be easy?
Iikka Konola - Responder
This product is still under warranty at the moment so I wouldn't want to risk taking that apart. But I highly presume the process should almost be the same.
dinoofsg -
Please... need to know if the battery is easy to replace at home on the Sony MDR-1000X Headphones. Thanks for any help.
Paul Allen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 157
Duração total: 73,891
