Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Intensity, use o nosso manual de serviço.
  1. Samsung Intensity Teardown, Samsung Intensity Teardown: passo 1, imagem 1 %32
    • Remove the back cover and battery
  2. Samsung Intensity Teardown: passo 2, imagem 1 %32
    • Remove the 8 screw that hold the back cover down.
    • Carefully pry back piece off
    • Start at the bottom and work toward the top.
  3. Samsung Intensity Teardown: passo 3, imagem 1 %32
    • Use the ipod opening tool to disconnect the Connector
  4. Samsung Intensity Teardown: passo 4, imagem 1 %32 Samsung Intensity Teardown: passo 4, imagem 2 %32
    • Carefully remove the main board
    • Make sure to not tear the microphone cable, pry it from the phone carefully
  5. Samsung Intensity Teardown: passo 5, imagem 1 %32 Samsung Intensity Teardown: passo 5, imagem 2 %32
    • Remove the 6 screws
    • Pry to ribbon cable assembly loose from the slider
    • Its glued on the left and right side
  6. Samsung Intensity Teardown: passo 6, imagem 1 %32
    • Remove the 4 screw the holds the slider to the phone assembly
    • one of the screws will be behind the hinge
    • Carefully pry slider assembly loose from display assembly
  7. Samsung Intensity Teardown: passo 7, imagem 1 %32 Samsung Intensity Teardown: passo 7, imagem 2 %32 Samsung Intensity Teardown: passo 7, imagem 3 %32
    • Remove the tape and pop the connectors and pull all the ribbon cables loose
    • Carefully pry the speaker loose from the case.
  8. Samsung Intensity Teardown: passo 8, imagem 1 %32
    • Carefully work the keyboard loose from the display assembly
    • There are a couple fragile clips that hold it in place
  9. Samsung Intensity Teardown: passo 9, imagem 1 %32 Samsung Intensity Teardown: passo 9, imagem 2 %32
    • LCD comes out pretty easily
    • Pry it from the bottom and work up the sides to release it if stuck
    • The glass can be removed with a little heat from a heat gun or blow dryer
    • Pry it out from the outside edges working around carefully
David
Membro desde: 08/10/11
148 Reputação
Autoria de 1 guia
1Comentário do guia
This was so helpful! How can I show my gratitude to you for these helpful instructions?
teh_pwnerer22 - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 4,843
