Introdução
Breaking news! Updated S9 Teardown Below!
There's a new Samsung Galaxy flagship phone in the world, the S9—and though you may have to squint to tell it apart from its predecessor, we're here to squint into its innards. It's time to tear down the Galaxy S9! Grab a spudger and let's poke around inside.
Were you hoping for something a little bigger? Try our S9+ teardown on for size.
Geek out with us on Facebook, Twitter, or Instagram, where we plug in with all our fellow tinkerers.
O que você precisa
Vídeo de Apresentação
This smaller version of the S9+ gets a big hardware upgrade. Let's take a look:
Notchless 5.8" AMOLED Display with resolution of 2960 × 1440 (~570 ppi)
Qualcomm Snapdragon 845 or Samsung’s own Exynos 9810, depending on location
12 MP OIS dual-aperture main camera—f/1.5 and f/2.4 modes—plus an 8 MP selfie cam
Headphone jack and microSD slot
IP68 water/dust-proofing rating
Android 8.0 Oreo
We start with a sneak peek—X-ray intel provided by our co-conspirators at Creative Electron.
If you liked the S8, we've got good news—Samsung agrees with you. The design seems almost totally unchanged, save for the new (and better) fingerprint sensor location.
Our S9 cozies up to its S8 ancestor on the left (reassembled from our 2017 teardown) and its S9+ sibling on the right (still sore from our teardown last weekend).
Props to Samsung for keeping the headphone jack and expandable storage, all while maintaining IP68 protection.
Getting inside a Galaxy phone hasn't gotten any easier lately, but at least the procedure is familiar:
Step 1: get it hot.
Step 2: add more heat.
Step 3: suction and slice, and don't hit that fingerprint sensor cable that you can't see.
You've probably heard us complain about this before, so we'll just add this: yes it's risky and tedious, but at least if you crack the back glass, you stand a chance of being able to replace it economically. (Our favorite fruit company is still working on that one.)
Ferramenta utilizada neste passo:iFixit Adhesive Remover$19.99
As if afraid the battery might run away, Samsung really didn't hold back on the glue.
Fear not! We've seen this before, and developed a secret formula for just this sort of sticky situation.
Remember when Samsung made a waterproof smartphone with a battery that you could swap in 10 seconds with no tools?
Although smaller than the S9+, the S9's battery is no slouch, and packs 3000 mAh at 3.85 V, for 11.55 Wh.
This is exactly the same as the S8, and a little larger than competitors like the Pixel 2 (10.39 Wh) and iPhone X (10.35 Wh).
Next we turn our attention to the brains of the phone, and after removing a few friendly Phillips screws, the motherboard slides free.
Near the top of the board we get a look at the S9's new heart rate and blood pressure sensors, a step up from the standard heart rate sensor seen on many phones.
Say hello to Dr. Bixby.
Compared to some flagships, the S9 has twice the f-stops and half the sensors.
Not shown: Samsung's highly touted 2 Gbit LPDDR4 DRAM, layered right underneath the image sensor.
Shown: Some other mystery chips.
RD938 likely OIS driver
STMicroelectronics L2G2IS 2-axis OIS gyroscope
GigaDevice GD25LQ32 32 Mb serial flash
We want to try out the S9's new dual aperture, but using the camera app seems a little too conventional.
After a bit of disassembly, a spudger seems to do the trick instead.
This may seem goofy, but the S9 really will have a small actuator that mechanically opens and closes the aperture—a mechanical bit that can fail.
Removing the lens also reveals the image sensor. Taking a closer look we see...yep that's an image sensor. Maybe some X-rays can show us that DRAM...
Lets take a look at the chips that power all that fancy hardware:
Samsung K3UH5H5OMM-AGCJ 32 Gb (4 GB) LPDDR4X DRAM, layered over a Qualcomm Snapdragon 845
Toshiba THGAF8G9T43BAIR 64 GB UFS (NAND flash + controller)
Avago AFEM-9096 front end module
Qualcomm Aqstic WCD9341 audio codec
Maxim MAX77705F PMIC
Skyworks SKY13716-1 low band front end module
IDT P9320S wireless power receiver likely similar to the P9320
There's another gathering of integrated circuits on the flip side:
Murata KM7N07016 Wi-Fi/Bluetooth module
NXP PN80T NFC controller
Qualcomm PM845 (likely PMIC)
Qualcomm SDR845 RF transceiver
Hard to make out, but we think this is likely the same Skyworks SKY78160-11 front-end module we found in the S9+
Qualcomm PM8005 PMIC
Qualcomm QDM3870 high-band diversity front-end module
IC Identification, pt. 2:
Maxim Integrated MAX98512 audio amplifier (1st one marked is unconfirmed)
Samsung S2MPB02 camera power management
Samsung S2MPB03 camera power management
Samsung S2DOS05 display power management
Qualcomm D5319 mid-band diversity front-end module
RDA Microelectronics RDA6213N FM transceiver (likely)
Qualcomm QET4100 envelope tracker
IC Identification, pt. 3:
NXP Semiconductor PCAL6524 24-bit I/O expander
ON Semiconductor FPF3688UCX load switch
Vishay DG2730 2-port, 480 Mbps USB 2.0 DPDT analog switch
ON Semiconductor FAN48618BUC53X 1 A boost regulator
Richtek RT8010GQW 1 A step-down DC-DC converter
Texas Instruments boost converter (likely)
NXP Semiconductor NCX2200 comparator
IC Identification, pt. 4 (sensors):
STMicroelectronics LSM6DSL 3-axis accelerometer/gyroscope
AKM Semiconductor AK09916C 3-axis electronic compass
STMicroelectronics LPS22HB pressure sensor
heart rate sensor
Ablic (formerly Seiko Instruments) S-5712CCDL1-I4T1U hall sensor
- Many components are modular and can be replaced independently.
- The battery replacement is technically possible, but accessing it is an unnecessary challenge.
- Glued-down glass both front and back means greater risk of breakage, and makes repairs difficult to start.
- Screen repairs require a lot of disassembly while battling tough adhesive.
Considerações finais
18Comentários do guia
Hello:
So, no radio on this model either?
Thanx for another great video and teardown explanation : )
that was perfect
Can you identify and break apart the RF front end please
Can the outer glass be replaced without replacing the entire lce
Technically but not worth the
