Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Galaxy Buds Plus, use o nosso manual de serviço.
    Considerações finais
    • External assemblies are held together with clips instead of glue, making for a non-destructive entry process.
    • Disassembly can be accomplished with common prying tools and a Phillips screwdriver.
    • The earbuds use rechargeable coin-cell batteries that are easier than ever to replace.
    • Opening procedure is a bit unorthodox, and can cause cosmetic damage to the buds.
    • Careful prying is required throughout to separate components without tearing fragile cables or otherwise damaging the buds.
    Índice de reparabilidade
    7
    Reparabilidade 7 de 10
    (10 é o mais fácil de reparar)
Taylor Dixon
Membro desde: 06/26/18
67.247 Reputação
Autoria de 94 guias
7 comentários
Would be nice if you could ID the rest of the major IC’s too.
Sean Davis - Responder
where can I find replacement parts?
Michel - Responder
More wireless earbud teardowns, please! I would also like to see the Galaxy Buds+ drivers.
Mike Housholder - Responder
possible to swap in a higher capacity battery for the buds+ and the case to increase total usable time in between charging.
K T - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 50
Últimos 30 dias: 243
Duração total: 20,304
