Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung GT-E1205Y, use o nosso manual de serviço.
  1. Samsung GT-E1205Y Teardown, Samsung GT-E1205Y Teardown: passo 1, imagem 1 %32 Samsung GT-E1205Y Teardown, Samsung GT-E1205Y Teardown: passo 1, imagem 2 %32
    • Welcome to my teardown of an Samsung GT-E1205Y!
    • In this teardown we will take apart an keypad phone without any touchscreen!
  2. Samsung GT-E1205Y Teardown: passo 2, imagem 1 %32 Samsung GT-E1205Y Teardown: passo 2, imagem 2 %32
    • Lets take off the back cover shall we?
  3. Samsung GT-E1205Y Teardown: passo 3, imagem 1 %32 Samsung GT-E1205Y Teardown: passo 3, imagem 2 %32 Samsung GT-E1205Y Teardown: passo 3, imagem 3 %32
    • Inside the back cover we have an 3,7 Volts 800mAh Li-ion battery which is enough for a phone like that.
  4. Samsung GT-E1205Y Teardown: passo 4, imagem 1 %32 Samsung GT-E1205Y Teardown: passo 4, imagem 2 %32
    • Looking further we have the following things:
    • Sim-Card Slot
    • Battery Pins
    • Unknown Pins which are labeled with letters?
    • If we zoom in we can actually see these letters close up, Mine was soldered at B, Everyone might have different soldering
  5. Samsung GT-E1205Y Teardown: passo 5, imagem 1 %32
    • Continuing with the teardown, We will have to unscrew the following screws
    • PH00 Screws
  6. Samsung GT-E1205Y Teardown: passo 6, imagem 1 %32 Samsung GT-E1205Y Teardown: passo 6, imagem 2 %32
    • After unscrewing them, I will make opening with a pick and then continue with a spudger
  7. Samsung GT-E1205Y Teardown: passo 7, imagem 1 %32
    • We are now inside the of the components of the phone! Hooray!!
  8. Samsung GT-E1205Y Teardown: passo 8, imagem 1 %32
    • Now its time to take out the keypad.
  9. Samsung GT-E1205Y Teardown: passo 9, imagem 1 %32 Samsung GT-E1205Y Teardown: passo 9, imagem 2 %32 Samsung GT-E1205Y Teardown: passo 9, imagem 3 %32
    • Now its time to take out the motherboard...
  10. Samsung GT-E1205Y Teardown: passo 10, imagem 1 %32 Samsung GT-E1205Y Teardown: passo 10, imagem 2 %32 Samsung GT-E1205Y Teardown: passo 10, imagem 3 %32
    • Lets take a look at the motherboard, At the second image I have labeled what the buttons do.
    • Looking at the back side of the motherboard we can see the following things
    • Battery Connector
    • Sim-Card Slot
    • Possible chip where the firmware is stored
    • Headphone and charger connector
  11. Samsung GT-E1205Y Teardown: passo 11, imagem 1 %32
    • Lets look at the shell. We have the following things!
    • Speaker
    • Vibrating Motor
  12. Samsung GT-E1205Y Teardown: passo 12, imagem 1 %32 Samsung GT-E1205Y Teardown: passo 12, imagem 2 %32 Samsung GT-E1205Y Teardown: passo 12, imagem 3 %32
    • Time to take out the speaker!
  13. Samsung GT-E1205Y Teardown: passo 13, imagem 1 %32 Samsung GT-E1205Y Teardown: passo 13, imagem 2 %32
    • And now lets take out the vibrating module!
  14. Samsung GT-E1205Y Teardown: passo 14, imagem 1 %32
    • Thats it! We have taken apart the following things!
    • Keypad
    • Battery
    • Speaker and Vibrator
    • Back and Front Shell
    • The Motherboard
    • And the back cover!
Artem Ivat
Membro desde: 02/05/20
3.362 Reputação
Autoria de 13 guias
Equipe
Kid fixers Membro de Kid fixers
Community
195 Membros
Autoria de 286 guias
1Comentário do guia
Phone on nahi ho raha hai
Ravindar Yadav - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 59
Ao todo: 1,971
