Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Samsung Connect Home, use o nosso manual de serviço.
  1. Samsung Connect Home Teardown, Samsung Connect Home Teardown: passo 1, imagem 1 %32 Samsung Connect Home Teardown, Samsung Connect Home Teardown: passo 1, imagem 2 %32 Samsung Connect Home Teardown, Samsung Connect Home Teardown: passo 1, imagem 3 %32
    • So what can this circuit-filled puck do?
    • Wi-Fi: 400 Mbps @ 2.4 GHz, 866 Mbps @ 5 GHz (AC1300).
    • Up to 1,500 square feet wireless coverage.
    • SmartThings connectivity via Bluetooth, Zigbee, and Z Wave.
    • Play hockey.
    • If you opted for the shinier Connect Home Pro, you get upgraded Wi-Fi capability:
    • Wi-Fi: 800 Mbps @ 2.4 GHz, 1,733 Mbps @ 5 GHz (AC2600).
  2. Samsung Connect Home Teardown: passo 2, imagem 1 %32 Samsung Connect Home Teardown: passo 2, imagem 2 %32
    • No, it's not a new probe droid—just the backside of the Connect!
    • Ever the minimalist, the Connect Home sports just three ports for power, WAN, and LAN, plus a reset pinhole.
    • Grill vents line all four sides of the bottom panel to keep the Connect cool.
    • The bottom sticker could contain interesting secret information, but all we found are serials numbers and wireless certifications.
  3. Samsung Connect Home Teardown: passo 3, imagem 1 %32 Samsung Connect Home Teardown: passo 3, imagem 2 %32 Samsung Connect Home Teardown: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    iFixit Opening Picks (Set of 6)
    Comprar
    • We start our search for screws in one of their favorite hiding places—under a rubber foot.
    • These are not the screw holes we're looking for. Oh wait, yes they are! Standard Phillips #00 too—kudos to Samsung for using common screws.
    • Not only do these opening picks get us inside some stubborn cases, but they can also give any device some cute flippers.
    • That said, it's probably not a good idea to let your Connect go swimming.
  4. Samsung Connect Home Teardown: passo 4, imagem 1 %32 Samsung Connect Home Teardown: passo 4, imagem 2 %32 Samsung Connect Home Teardown: passo 4, imagem 3 %32
    • It must get really hot in here—the first thing we spy is a massive ducted heatsink! What could this be cooling?
    • And if we thought the Home had a big heatsink, the Connect Pro gets a fan too!
    • That's some serious cooling for an otherwise inconspicuous router.
    • We take a look under the Connect's heatsink to find a large shielded area—just another barrier to our chip curiosity.
  5. Samsung Connect Home Teardown: passo 5, imagem 1 %32 Samsung Connect Home Teardown: passo 5, imagem 2 %32 Samsung Connect Home Teardown: passo 5, imagem 3 %32
    • On the back of the board we spy the Z-wave antenna (the black rectangle on the left), and some metal contact clips mounted in the case.
    • The board has some coaxial connectors, but seems to be using spring contacts instead—a nice repair-friendly, low wear connection option.
    • And finally, a lone LED handles the task of communicating the Connect's status to the world. Stay strong little guy!
  6. Samsung Connect Home Teardown: passo 6, imagem 1 %32 Samsung Connect Home Teardown: passo 6, imagem 2 %32
    • With the EMI shields unsealed, let's see what treasures lie revealed:
    • Qualcomm IPQ4019 SoC—the main brains of the device, and the reason for the giant heatsink
    • Qualcomm Atheros QCA8072 ethernet switch on a chip
    • Sigma Designs SD3503 serial interface modem SoC
    • Samsung K4B4G1646E-BYK0 512MB DDR3L SDRAM
    • Samsung KLM4G1FEPD-C031 4GB NAND Flash memory
    • Silicon Labs EFR32MG1B232F256GM48 Zigbee radio controller
    • Qualcomm (formerly Cambridge Silicon Radio) CSR8811 Bluetooth 4.1 radio
  7. Samsung Connect Home Teardown: passo 7, imagem 1 %32 Samsung Connect Home Teardown: passo 7, imagem 2 %32
    • How does the Pro version compare? Here are the major differences:
    • CPU upgrade: Qualcomm IPQ8065 SoC quad-core network processor (vs. IPQ4019)
    • Ethernet switch upgrade: Qualcomm QCA8337 (vs. QCA8072)
    • RAM upgrade: Two Samsung K4B4G1646E-BYK0 512MB DDR3L SDRAM (instead of one)
    • Two Qualcomm QCA9984 802.11ac radio SoC's, which allows more devices to connect at faster speeds.
    • More power sources and converters to handle the added load.
  8. Samsung Connect Home Teardown: passo 8, imagem 1 %32
    • We have reached the end of the tour. Thank you for choosing iFixit as your site for repair manuals and cool teardowns.
  9. Considerações finais
    • The case is held together with standard screws and reusable plastic clips.
    • All antennas easily detach from the main board thanks to spring contacts.
    • While they're not likely to need replacement, the ports are soldered onto the main board, complicating repair.
    Índice de reparabilidade
    8
    Reparabilidade 8 de 10
    (10 é o mais fácil de reparar)
5 comentários
Is that a hidden USB port at the lower left of the first images of Step 6 and 7? If so, does it work?
azureskies - Responder
Yes! It is a hidden micro-USB port. We guess that it’s for debugging/programming purposes. No, we have not tried it yet.
Arthur Shi -
Does the coexistence design applied in this router like PTA ? How was the zigbee performance while a big file is downloading through this router ?
Guojun Qin - Responder
How is this difference from Samsung’s smarthings wifi mesh system ??? Specs wise
Kal Jak - Responder
Where can I buy mother board for this device? Mine is not powering up, I don’t see any light coming up. Kindly suggest.
S P - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 5,268
