Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Rogue G10, use o nosso manual de serviço.
  1. Rogue G10 Teardown, Rogue G10 Teardown: passo 1, imagem 1 %32 Rogue G10 Teardown, Rogue G10 Teardown: passo 1, imagem 2 %32 Rogue G10 Teardown, Rogue G10 Teardown: passo 1, imagem 3 %32
    • Here is the front view of the Rogue G10 amp.
    • Back side shows 4 Phillips head screws that need to be removed.
    • Here are the 4 #6x1" screws
  2. Rogue G10 Teardown: passo 2, imagem 1 %32 Rogue G10 Teardown: passo 2, imagem 2 %32 Rogue G10 Teardown: passo 2, imagem 3 %32
    • Use a small screwdriver or other small suitable prying instrument to remove the back cover.
    • With the back cover removed the speaker and amp become visible.
    • Remove the 2 Phillips head screws from the carrying handle. These two screws also attach the amp to the onside of the case.
  3. Rogue G10 Teardown: passo 3, imagem 1 %32 Rogue G10 Teardown: passo 3, imagem 2 %32 Rogue G10 Teardown: passo 3, imagem 3 %32
    • Here are the two screws from the handle. They are 1/8"x1 1/4"
    • Remove the 16 screws from the plastic corners. These corners serve no purpose other than decoration.
    • There are 4 rubber feet on the bottom of the amp.
  4. Rogue G10 Teardown: passo 4, imagem 1 %32 Rogue G10 Teardown: passo 4, imagem 2 %32 Rogue G10 Teardown: passo 4, imagem 3 %32
    • This shows the corners with the screws removed.
    • Remove the rubber feet by removing the Phillips head screws.
    • On the left and right side of the amp is a Phillips head screw, located 1/3 down from the top and to the front. These two screws hold the front panel to which the speaker is attached. Remove those.
  5. Rogue G10 Teardown: passo 5, imagem 1 %32 Rogue G10 Teardown: passo 5, imagem 2 %32 Rogue G10 Teardown: passo 5, imagem 3 %32
    • Here is the one on the right side, same location.
    • Remove it as well
    • With those two screws removed, the front panel which houses the speaker, can be simply removed
  6. Rogue G10 Teardown: passo 6, imagem 1 %32 Rogue G10 Teardown: passo 6, imagem 2 %32 Rogue G10 Teardown: passo 6, imagem 3 %32
    • remove the front panel and place aside.
    • With the front panel removed, the amp will now simply lift out as well
    • Here is the amp totally disassembled. Straight forward job. No glue, no hidden screws.
oldturkey03
Membro desde: 09/29/10
784.351 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 560 guias
4 comentários
Do these models have tubes in them?
Camron Buxton - Responder
No, they do not. Strictly solid state
oldturkey03 -
What may be causing the scratchy sound only when playing on my G10? Tried multiple cables and cleaned the input with electrical contact cleaner and there was no change. If I run a cable from the Phones jack to my computer input then the noise is not there.
Brian Day - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 34
Duração total: 3,147
