Nintendo's brand new handheld console, the 2DS XL can play all your 3DS games in 2D. But what happens when we break out our tools and bring the 2DS into the teardown dimension?????
When you have to give someone else a turn to play, find us on Facebook, Instagram, or Twitter to learn something new.
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua New Nintendo 2DS XL, use o nosso manual de serviço.
In the teardown video they show how to remove the ribbon cable, but beware! Two of these cable dont have the regular easy fit where you lift the flick to get it open and remove the cable. (Yes, they do this in the video and brake it.) Once they’re open” they wont close again.
The cable right above the cart slot is ond and the closes cabel to the joystick is the other. (The two with the back connectors)
BEWARE!
I have not tested this yet but it seems as it is a tight push fit to these ribbon cables.
If there is so, please let other people know so they dont do the same mistake as i by opening it and cannot close it again.
19 comentários
yet another yootoob tear-down...why? whats wrong with the others - some peeps cant get to yootoob during the day!
P Stephenson - Responder
Any idea how I can get my hands on a replacement back frame. I found a crack in the bottom right corner.
Nathaniel Canning - Responder
Why can’t i find a direct 2ds close upper screen replacement? Is it the same screen as the 3Ds Xl?
John - Responder
It’s not the same, the 2DS screen is in 2D and the 3DS has a 3D screen
Liam Judge -
Warning!
BEWARE!
In worst case your New 2DS XL turn on!
Daniel - Responder
