Ferramentas utilizadas neste teardown
Introdução
We've had a busy week since Apple announced its new products at WWDC on June 11, 2012. We just couldn't stop after digging in to the MacBook Pro with Retina Display and the MacBook Air, so we got our hands on the Mid 2012 MacBook Pro. While its sibling with the Retina display may have stolen all the press, this MacBook Pro is nothing to scoff at. It's way more repairable and upgradeable than its sleeker-looking sibling. Follow along as we show you inside.
Stay tuned to all the latest teardowns and updates by following us on Twitter.
Drum roll please…we've got Apple's mid 2012 update of the the MacBook Pro and we are ready to get inside.
The impressive machine boasts:
2.3 GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.3GHz) with Intel HD Graphics 4000
NVIDIA GeForce GT 650M GPU with 512 MB of GDDR5 VRAM
4 GB of 1600 MHz DDR3 RAM
500 GB 5400 RPM hard drive
15.4" 1440x900 (110 ppi) LED-backlit display
USB 3.0 and Thunderbolt I/O
We wanted to see how the Mid 2012 MacBook Pro stacked up against its new sibling, the MacBook Pro with Retina display. Other than the difference in size, the main differences between the machines are:
Hard disk drive vs. flash storage
8 GB vs. 16 GB maximum configurable RAM (from Apple, at least)
One Thunderbolt port vs. two
MagSafe vs. MagSafe 2
Kensington lock slot vs. flat aluminum
Oh yeah…and a standard or Hi-Res (on 15-inch model) LCD vs. a Retina display
Not surprisingly, ten Phillips screws stand between us and the inside of the updated Pro.
We are relieved to see such a familiar sight. With no adhesive or pentalobe screws anywhere to be seen, we are excited to get at the upgraded insides of the new Pro.
The only "funky" bit we came across in the MacBook Pro was a Y0 Tri-point screw holding down the battery. Luckily, we were prepared and had our 54-Bit Driver Kit on hand.
Our faithful spudger helps us disconnect the battery, which you should always do when performing repairs or maintenance on your MacBook Pro.
Apple's battery warning labels haven't stopped us before, and they're not stopping us now.
The battery is exactly the same as last year's model—77.5 Wh at 10.95 V.
In case you missed it last year, this battery is 13.8 mm thick and weighs 450 g.
By comparison, the battery in the MacBook Pro with Retina display has cells that vary in thickness from 5.25 mm to 8.60 mm.
Standard Phillips screws secure the 500 GB Toshiba hard drive, meaning upgrading to a larger drive will be easy after you decide to start shooting RAW.
2.5" profile and a spinning platter? This hard drive is
old newsstill perfectly good for most users' needs. -
The 2.5" SATA drive in this MacBook Pro is almost three times as thick as the proprietary SSD in the MacBook Pro with Retina display: 9.45 mm compared to 3.16 mm, respectively.
The drive has 4 mounting posts/screws that can be removed using a T6 torx bit.
Round two with the spudger frees the AirPort/Bluetooth board and unearths the optical drive.
Hot chips on the wireless card:
Broadcom BCM4331KML1G 802.11n wireless solution
Broadcom BCM20702 Bluetooth processor
Skyworks SE5503A 802.11a/b/g/n Wireless LAN
The optical drive is held in place with more standard Phillips screws.
A sigh of relief for anyone who wants to replace their optical drive with an SSD enclosure for more storage with enough room for all 736 episodes of Power Rangers and to install all 36 GB of Age of Conan.
It seems likely that this will be Apple's last laptop with an optical drive.
By the way: we also make software for teaching people to do things. Dozuki makes it easy to create vibrant how-to manuals.
Dozuki is great for:
Standardized work instructions: improve quality by documenting how to get things done, one step at a time.
Building product support sites: make your customers love you by teaching them how to do amazing things.
Training and e-learning software: we've used Dozuki to teach over ten million people to repair electronics.
Online community platform: build a knowledge base of expert knowledge with Answers, the Q&A engine that drives the popular iFixit Answers.
Next we pulled out our favorite flavor of RAM: user-serviceable.
While you can only configure your MacBook Pro with up to 8 GB of RAM from Apple, you can install up to 16 GB yourself with no issues.
This is another sigh of relief from those DIYers who
wantneed to upgrade their RAM on an annual basis. -
While the individual RAM modules here are thin (~3.15 mm), the "stacked" RAM slot is a whopping 9.15 mm thick.
When your entire device is only 18 mm thick, allocating half of that dimension to RAM slots can be too much of a sacrifice, as we have witnessed in the MacBook Air and now in the MacBook Pro with Retina display.
Don't lose hope! An individual RAM slot is only 4.27 mm thick. If the design of the logic board would feature the RAM slots side by side, we could still see user-replaceable RAM for years to come.
The spudger is back out as we remove the fan.
Three standard Phillips screws and a connector are all it takes to remove the fan for dust bunny extermination.
Unlike its cousins, the 2012 MacBook Pro does not have irregularly-spaced fan blades. Just boring old fans in here.
Front side of the logic board:
Intel Core i7-3615QM 2.30 GHz quad-core processor with Turbo Boost (labeled as Intel C208A046 SR0MP)
What appears to be an Intel E2088369 Platform Controller Hub
Intel L206IA58
Broadcom BCM57765B0KMLG Integrated Gigabit Ethernet and Memory Card Reader Controller
Parade PS8301
Texas Instruments Stellaris LM4FS1AH microcontroller with integrated ARM core
Back side of the logic board:
Hynix H5GQ1H24BFR 1 Gb GDDR5 SDRAM (Total of 4 Gb = 512 MB)
Maxim MAX15119 Apple-specific IMVP7 CPU/GPU power controller
Cirrus Logic 4206BCNZ Audio Controller
SMSC USB25138 USB controller
Lattice Semiconductor LFXP2-5E Low-Cost Non-Volatile FPGA
Cypress Semiconductor CY8C24794-24L - a Programmable SoC
Infineon 62882C
There you have it, all the screws from the MacBook Pro Mid 2012, on our fancy magnetic project mat. As you can see there are no pesky pentalobe screws, just Phillips, Torx, and Tri-Wing.
By the way, we don't just make awesome teardowns—we sell parts. And tools! Lots and lots of tools.
Like this handy-dandy electronics tool kit that we used to take apart the new iPad. You know you want one. It'll pay for itself the first time you use it!
We sell Mac parts & upgrades, parts for iPhone screen repair, kits for fixing the infamous Xbox Red Ring of Death, and tons more.
We need your support to continue building the free repair manual for everything in the world.
MacBook Pro 15" Unibody Mid 2012 Repairability Score: 7 out of 10 (10 is easiest to repair).
Easily removable bottom panel and readily accessible battery, optical drive, hard drive, fans, and RAM.
Standard screws were used for all components, save for the battery.
Significant amounts of thermal paste may be a pain in later repairs.
Tri-wing screws on the battery require a specialty driver that an average user may not have.
LCD replacement is still the most difficult repair. Inexperienced (and even experienced) technicians may shatter the glass during repair.
15 Comments
On the logic board:
4Gb = 512 Mb??. Isn't 4Gb, you know = to 4Gb? Or does Gb mean something different in this context. There must be something here I'm not following
"Gb" is actually Gigabits, not Gigabytes. The difference is in the capitalization of the "b."
GB = Gigabytes
Gb = Gigabits
MB = Megabytes
Mb = Megabits
Eight bits in a byte, so 8 Gb = 1 GB... And 4Gb = 512 MB.
