Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Mac mini Late 2018, use o nosso manual de serviço.
  1. Mac mini Late 2018 Teardown, Mac mini Late 2018 Teardown: passo 1, imagem 1 %32
    • This Mac might be mini, but it's packing some big specs. Let's unpack some here:
    • 3.6 GHz quad-core Intel Core i3 with 6 MB shared L3 cache
    • 8 GB of 2666 MHz DDR4 SO-DIMM memory
    • 128 GB SSD
    • Intel UHD Graphics 630
    • 802.11ac Wi-Fi + Bluetooth 5.0
    • macOS Mojave
  2. Mac mini Late 2018 Teardown: passo 2, imagem 1 %32 Mac mini Late 2018 Teardown: passo 2, imagem 2 %32 Mac mini Late 2018 Teardown: passo 2, imagem 3 %32
    • Our first look at the 2018 mini's exterior gives us the warm and fuzzies—it's the same friendly form factor we remember.
    • Some folks speculated that if Apple ever updated the mini, it'd look something like an Apple TV. Thankfully, Apple didn't succumb to the urge to go thinner and lighter this time—this is no Mac micro.
    • Apart from the new color, we also have some new identifiers: model A1993 and EMC 3213.
    • Despite controversial departures from a few common ports, Apple has included plenty of them here! We spot two USB-A ports, four USB-C ports, a headphone jack, an ethernet port, and an HDMI port (which isn't available on any other recent Apple product).
    • We'll see if any of these ports are modular. The latest MacBook Air certainly got our hopes up!
    • We'd like to think we know our way in—but after four years without an update, we're not taking anything about this opening procedure for granted.
    • With some trepidation, we point our tools at the 60%-recycled-plastic bottom cover.
    • Success! An opening tool takes care of the base, and six quick stabs with the TR6 Torx security driver loosens the familiar antenna plate underneath.
    • So far so good. Fingers crossed that this keeps up!
  3. Mac mini Late 2018 Teardown: passo 4, imagem 1 %32 Mac mini Late 2018 Teardown: passo 4, imagem 2 %32 Mac mini Late 2018 Teardown: passo 4, imagem 3 %32
    • Just like the last couple times we did this, we're greeted first by a single fan standing watch over the mini's insides.
    • The fan unscrews with zero fuss, giving us a better view of the mini's depths.
    • Theoretically, we just need to unplug these cables from the logic board, and it'll be free to slide right out of the chassis.
    • Theoretically.
    • It's time to improvise—our handy Mac mini logic board removal tool technically fits in the logic board's screw holes, but it doesn't feel right. We're going to need more leverage.
    • Could it be that some good old-fashioned thumb pressing does the trick? It does! A firm push on either side of the blower exhaust is all it takes, and the whole board unclips and slides out.
    • As much as we love making great tools, nothing makes us happier than seeing something you can service with no tools at all.
    • Who knows, maybe Apple does have a tool to push without endangering those thin exhaust fins, but carefully aimed thumbs works for us!
  4. Mac mini Late 2018 Teardown: passo 6, imagem 1 %32 Mac mini Late 2018 Teardown: passo 6, imagem 2 %32 Mac mini Late 2018 Teardown: passo 6, imagem 3 %32
    • With the board out, we're going straight for the RAM. Apple has trapped it in a heavy metal cage—almost as if they don't fully trust modular RAM to behave itself.
    • Actually though, we've seen this in iMacs of yore. The shield allows the RAM to operate at high frequency (2666 MHz) with no chance of accidentally interfering with other functions.
    • Twirl away four Torx screws, and the cage slides right off. Has RAM replacement ever been easier?
    • Sure it has—but, the return to standard SO-DIMM RAM after the bitter disappointment of the 2014 mini's soldered-down chips is a huge win. Upgrade now, or upgrade later—you have a choice again.
    • We pop out two SKhynix HMA851S6CJR6N 4 GB DDR4-2666 SDRAM modules, each with four 1 GB H5AN8G6NCJR DDR4 SDRAM ICs.
  5. Mac mini Late 2018 Teardown: passo 7, imagem 1 %32 Mac mini Late 2018 Teardown: passo 7, imagem 2 %32 Mac mini Late 2018 Teardown: passo 7, imagem 3 %32
    • Just one connector and two screws sets the little system speaker free.
    • iMac and MacBook speakers seem to be getting bigger all the time, but this one looks about the same size as in older Mac minis.
    • Beneath the speaker, we find some antenna cables, but unfortunately no modular AirPort card—in what is becoming a trend, these are socketed right to the main board.
    • Alas, AirPort cards are just a distant memory now that logic boards have assimilated all wireless functions.
    • From here we set to work freeing the heatsink, twirling away Torx screws and exposing the paste-y (soldered) CPU.
    • One last screw, and the port cover is free, uncovering ... the ports. As it departs, it takes some antenna hardware with it.
  6. Mac mini Late 2018 Teardown: passo 8, imagem 1 %32 Mac mini Late 2018 Teardown: passo 8, imagem 2 %32
    • This mini still holds a lot of silicon—let's take a look!
    • 3.6 GHz quad-core Intel Core i3 CPU with Intel UHD Graphics 630
    • Toshiba TSB3225V81199TWNA1 flash storage (32 GB each, 128 GB total)
    • Apple APL1027 339S00604 T2 coprocessor
    • Intel SR40E CM246 platform controller hub
    • Intel JHL7540 Thunderbolt 3 controller
    • Broadcom BCM57766 Gigabit Ethernet controller
    • 338S00342-A0 (likely an Apple PMIC)
  7. Mac mini Late 2018 Teardown: passo 9, imagem 1 %32 Mac mini Late 2018 Teardown: passo 9, imagem 2 %32
    • And the backside holds even more:
    • Murata 339S00458 Wi-Fi / Bluetooth module
    • MegaChips MCDP2920A4 DisplayPort 1.4 to HDMI 2.0 converter
    • Cirrus Logic CS42L83 audio codec
    • Texas Instruments TPS51916 memory power solution w/ synchronous buck controller
    • Texas Instruments CD3215C00 USB-C controller x4
    • Texas Instruments CSD58872Q5D NexFET synchronized buck power block
    • Intersil ISL95828AHRTZ CPU power controller
  8. Mac mini Late 2018 Teardown: passo 10, imagem 1 %32 Mac mini Late 2018 Teardown: passo 10, imagem 2 %32
    • Chip identification, continued:
    • Infineon (formerly International Rectifier) IRF3575 60 A synchronous buck converter
    • Renesas (formerly Intersil) ISL62383C power supply controller
    • Vishay SIC621 60 A integrated power stage
    • Renesas (formerly Intersil) ISL80101A 1 A LDO regulator
    • Texas Instruments INA210 bi-directional current sense amplifier
    • Texas Instruments INA211 bi-directional current sense amplifier
    • Texas Instruments INA214 bi-directional current sense amplifier
  9. Mac mini Late 2018 Teardown: passo 11, imagem 1 %32 Mac mini Late 2018 Teardown: passo 11, imagem 2 %32
    • Dialog Semiconductor (formerly Adesto) AT45DB021E 2 MB serial flash memory
    • Macronix MX25R2035F 2 MB serial NOR flash memory
    • Winbond W25Q80EW 8 MB serial NOR flash memory
    • Winbond W25Q80DW 8 MB serial NOR flash memory
    • ON Semiconductor CAT24C128 128 KB serial EEPROM memory
    • Texas Instruments HD3SS215 6.0 Gbps HDMI DisplayPort differential switch
    • Diodes Incorporated PI3USB32 dual SPST USB 2.0 switch
  10. Mac mini Late 2018 Teardown: passo 12, imagem 1 %32 Mac mini Late 2018 Teardown: passo 12, imagem 2 %32
    • Texas Instruments TMP464 5-channel temperature sensor
    • Texas Instruments TMP103 temperature sensor
    • Texas Instruments TAS5770 audio amplifier
    • Texas Instruments TPS2561 2-channel power switch
    • Apple 338S00410 power management IC
    • Texas Instruments TPS62684 1.6 A step-down converter
    • Dialog Semiconductor SLG59M301V 4 A load switch
  11. Mac mini Late 2018 Teardown: passo 13, imagem 1 %32 Mac mini Late 2018 Teardown: passo 13, imagem 2 %32 Mac mini Late 2018 Teardown: passo 13, imagem 3 %32
    • The last thing between us and an empty mini is the internal power supply!
    • The linchpin holding this unit in place is a familiar one—so familiar that we follow our own repair guide to remove it.
    • The power supply is a nice enclosed unit, making for safe, easy replacement.
    • The only thing it's missing is a cute label.
    • The mini power supply gets an upgrade from days past, jumping from 85 watts to 150.
  12. Mac mini Late 2018 Teardown: passo 14, imagem 1 %32
    • It appears we've maxed out our mini, feast your eyes on these cool components!
    • Back in the day, a Pro Mac meant a computer you could upgrade, configure, and connect as you pleased. This new mini aligns so well with that ideal that we're surprised it didn't earn itself a "Pro" title—especially compared to the increasingly closed-off MacBook Pro line.
    • Perhaps the most exciting part of this mini is a return to upgradable RAM. In fact, our users are so excited they already made a RAM replacement guide. Stay tuned for the official guide and upgrade kits!
  13. Considerações finais
    • No tough adhesive holds the Mac mini or its components hostage.
    • Using fairly common tools, disassembly is straight-forward.
    • The mini packs standard SO-DIMMs allowing both DIY upgrades and replacements.
    • The CPU and storage are both soldered to the logic board and not user-upgradeable.
    • If any of the many ports is damaged or worn, the entire logic board will need replacing.
    Pontuação de reparabilidade
    6
    Reparabilidade 6 de 10
    (10 é o mais fácil de reparar)
107 comentários
How about Drives? Can you put a second one like you could on older ones?
poliva - Responder
No. You can’t even remove the built-in SSD.
Paul -
Not only is there no room in this design, but there are also no available SATA or PCIe connectors which would allow you to upgrade the internal storage.
repoman27 -
with that many thunderbolt ports, I think the real goal with this mini is to update it with external drives and GPUs. Upgrade the RAM and add modules, seems like a good compromisse from the 2014 model
Diego Azevedo -
As long as apple keeps using their private Tx chips as the ssd main controller, we are unlikely to use a common pcie ssd in those macs.
Orange Chen -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 82
Últimos 7 dias: 553
Últimos 30 dias: 2,361
Duração total: 348,836
