Introdução
We will not be tearing the whole thing apart; just the big pieces
This loudspeaker was tinkered at the charge port (installation of a new one).
O que você precisa
Vídeo de Apresentação
Use a plastic spatula or credit card to open the grids
You should not have to exert too much force on the grids. There is a little bit of glue on it.
Remove the first 4 screws
Blow up the round of plastic then take care of the remaining 4 screws.
Now you can access the motherboard.
To disconnect the battery: disconnect the microphone first, it will make things easier.
Unscrew the two screws of the white cover
Get out of his notch, and here's the battery!
9 outras pessoas concluíram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
11 comentários
About to try this, will give feedback
This is the charge2 + not the charge2
there aren,t any screws in the cap
I have the same problem. I think this is a TL model, but I have not been able to find any information on how to correctly remove the end caps. I don’t want to scratch or break anything trying to pop the end caps off.
Bobcov -
Thanks so much! I had a broken bit of plastic inside the tube after I left my speaker in my checked luggage and it got smashed around. I followed the instructions and managed to get it out, the speaker is purring again without the annoying ass rattle!! You're a legend my friend. TY
