Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Galaxy S23, use o nosso manual de serviço.
  1. Galaxy S23 Teardown, Remove the rear glass: passo 1, imagem 1 %32 Galaxy S23 Teardown, Remove the rear glass: passo 1, imagem 2 %32
    • First we heat the rear glass of the phone to melt all the adhesive that glues the glass to the rest of the phone. We can do it either with an iOpener or with a heat gun.
    • Now with a flat object or with an opening pick we cut the remaining adhesive by inserting it between the glass and the rest of the phone and passing it along the entire edge.
    • Now we can raise the back panel and we're done.
  2. Galaxy S23 Teardown, Remove the Wireless Coil and NFC Antenna: passo 2, imagem 1 %32
    • Unscrew the 6 Phillips #00 screws that weld the wireless charging base and the NFC antenna.
    • Disconnect the connector connecting the two antennas and remove everything.
  3. Galaxy S23 Teardown, Disconnect the Battery: passo 3, imagem 1 %32
    • Unplug the connector to disconnect the battery.
  4. Galaxy S23 Teardown, Unscrew the Charging Board: passo 4, imagem 1 %32
    • Remove the 7 #00 Phillips screws that secure the charging board to the rest of the phone.
  5. Galaxy S23 Teardown, Remove the SIM: passo 5, imagem 1 %32
    • Use a fine tool to pull out the SIM tray.
  6. Galaxy S23 Teardown, Remove the connectors: passo 6, imagem 1 %32
    • Remove the connector with your fingers or a flat tool.
  7. Galaxy S23 Teardown, Remove the Front Camera Protector: passo 7, imagem 1 %32
    • Unscrew the 5 Phillips #00 screws that secure the front camera protector to the rest of the phone.
  8. Galaxy S23 Teardown, Remove the Front Camera: passo 8, imagem 1 %32
    • Unplug the front camera connector and remove it.
  9. Galaxy S23 Teardown, Remove the Rear Cameras: passo 9, imagem 1 %32 Galaxy S23 Teardown, Remove the Rear Cameras: passo 9, imagem 2 %32
    • Remove the two Phillips #00 screws that secure the rear camera protector to the rest of the phone.
    • Unplug the three connectors of the three rear cameras and remove them.
  10. Galaxy S23 Teardown, Remove the Charging Board: passo 10, imagem 1 %32
    • Unscrew the three Phillips #00 screws that secure the docking board to the rest of the phone and then remove it.
  11. Galaxy S23 Teardown, Remove the battery: passo 11, imagem 1 %32 Galaxy S23 Teardown, Remove the battery: passo 11, imagem 2 %32 Galaxy S23 Teardown, Remove the battery: passo 11, imagem 3 %32
    • With the special tab, detach it and pull to facilitate the removal of the battery.
  12. Galaxy S23 Teardown, Remove add-ons: passo 12, imagem 1 %32 Galaxy S23 Teardown, Remove add-ons: passo 12, imagem 2 %32
    • Remove the volume keys motherboard and them too.
  13. Galaxy S23 Teardown, Finished: passo 13, imagem 1 %32
    • We have completely disassembled the new Samsung Galaxy S23.
Andrea Alfani
Membro desde: 04/20/22
7.697 Reputação
Autoria de 5 guias
Equipe
Kid fixers Membro de Kid fixers
Community
Membros da 162
Autoria de 301 guias
8 comentários
You beat iFixit to the punch! Nice work. They're really falling behind. Good thing we have awesome users like yourself! Thank you!
Damien Lobb - Responder
Thank You so much i really appreciate it thank you so much i really appreciate it
Andrea Alfani -
Will the microphone get damage if I wrongly insert the sim pin into it?
apple terr - Responder
Mine did not damaged, all works properly)
Ramil Salakhetdinov -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 55
Últimos 7 dias: 343
Últimos 30 dias: 1,661
Duração total: 28,383
