Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Galaxy Note10 Plus, use o nosso manual de serviço.
    Considerações finais
    • Equally-sized Phillips fasteners means you only need to bring one driver for repairs.
    • Many components are modular and independently replaceable, but no more headphone jack means double duty for the USB-C port.
    • Every repair starts with painstakingly un-gluing the fragile glass rear cover.
    • Replacing the glued-down battery is tougher than ever, especially with board interconnect cables to work around.
    • All-too-common display repairs require either a complete teardown or replacing half the phone.
    Índice de reparabilidade
    3
    Reparabilidade 3 de 10
    (10 é o mais fácil de reparar)
Taylor Dixon
Membro desde: 06/26/18
71.614 Reputação
Autoria de 94 guias
10Comentários do guia
Samsung note s10+ fix
kamran.abbas10i - Responder
i drop my Samsung Note 10+ and broke the display how can i replace it
Hussain Shiyan - Responder
Sorry but the camera lens is apart of the actual rear glass.
ducky draws -
Please add how to replace the rear camera lense onle without having to take the back glass off.
Fawaz Tariq - Responder
What are you guys return policy because i received the wrong screen. Instead of the Galaxy S10 + screen i needed my Galaxy Note 10+ one. I haven’t taken the other screen out the wrapper yet.
William Rozier - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 116
Ao todo: 31,134
