Ir para o conteúdo principal
CR-10 V2 Print Head Teardown
O que você precisa
  1. CR-10 V2  Print Head Teardown, Teardown: passo 1, imagem 1 %32 CR-10 V2  Print Head Teardown, Teardown: passo 1, imagem 2 %32 CR-10 V2  Print Head Teardown, Teardown: passo 1, imagem 3 %32
    • Make sure all power cables to your 3D Printer are unplugged including wall plugs (A/C) and/or USB cables.
    • Using M2 hex remove the 3 button head screws holding the print head to the X carriage plate.
    • Using M2 hex, remove the 4 screws holding the hot end fan in place (2 screws attach to the front half and the other to the rear)
    • Using M2 hex, remove 3 button head screws that secure front and rear sections together. Do not try to pull apart yet!
  2. CR-10 V2  Print Head Teardown, Teardown: passo 2, imagem 1 %32 CR-10 V2  Print Head Teardown, Teardown: passo 2, imagem 2 %32 CR-10 V2  Print Head Teardown, Teardown: passo 2, imagem 3 %32
    • Using M2 hex, remove the 2 button head screws securing the part cooler fan. 1 attaches to the front and the other to 2 rear.
    • Pull the front half off to expose the rear section and hot end.
    • Now, treat it like an E3D V6 hot end. However, the nozzle is not V6 style.
    • The stock nozzle is MK8 just like standard CR-10/ CR-10S
Conclusão
3 outras pessoas executaram este guia.
Tiny Machines 3D
Membro desde: 11/16/19
2.970 Reputação
Autoria de 14 guias
Equipe
Tiny Machines 3D Membro de Tiny Machines 3D
Community
Membros da 5
Autoria de 40 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 22
Duração total: 8,060
