Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Fan, use o nosso manual de serviço.
    1. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: passo 1, imagem 1 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: passo 1, imagem 2 %32
      • Gather the required tools: a small Phillips head screwdriver and a smart wrench.
      • Make sure the device is unplugged and fan blade is not spinning before starting.
      Pergunte ao FixBot
      Comentar
    2. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: passo 2, imagem 1 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: passo 2, imagem 2 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: passo 2, imagem 3 %32
      • Unscrew the clip-on stand that connects the fan. This can be done by hand.
      • Turn the fan so that the back is facing up and remove the screw on the upper part of the housing.
      • Remove the back casing to reveal the switch's screws on the inner part of the casing. Remove those as well.
      • The switch's settings:
      • Off (center)
      • Speed 1 (left)
      • Speed 2 (right)
      Pergunte ao FixBot
      Comentar
    3. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: passo 3, imagem 1 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: passo 3, imagem 2 %32
      • Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
      • Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
      Pergunte ao FixBot
      Comentar
    4. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: passo 4, imagem 1 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: passo 4, imagem 2 %32
      • Now that the blade is removed. The motor can now be removed from the other half of the housing.
      • Remove the two screws indicated in order to take the module out of the plastic.
      • The motor is connected to the blue transformer. The yellow and white wires indicate the two power outputs for the speed of the motor's rotation.
      Pergunte ao FixBot
      Comentar
    5. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown: passo 5, imagem 1 %32
      • That's it! There isn't too much when taking this device apart.
      • Note: You can further expand on the teardown by taking apart the transformer to DC motor set-up, but it's such a simple circuit that it isn't necessary to look at it.
      Pergunte ao FixBot
      Comentar
Justin
Membro desde: 12/08/14
111 Reputação
Autoria de 1 guia
4Comentários do guia
Hi How do you find the replacement switch?
sadeyealso - Responder Compartilhar
the switch melted….
Hi, I was wondering where I could find a clip and base for a 6 inch fan. The fan itself works just fan. Preferably it should be an online store.
Thanks for reading.
Nova Apex - Responder Compartilhar
Is it possible to purchase a replacement blade?
Wayne - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 91
Ao todo: 5,485
