Ir para o conteúdo principal
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Bose QuietComfort 35, use o nosso manual de serviço.
  1. Bose QC25, QC35, & QC45 Teardown, Prepararations: passo 1, imagem 1 %32 Bose QC25, QC35, & QC45 Teardown, Prepararations: passo 1, imagem 2 %32 Bose QC25, QC35, & QC45 Teardown, Prepararations: passo 1, imagem 3 %32
    • Have a small magnet to collect the tin screws, magnetize your screwdrivers with a 'meagnetizer' .
  2. Bose QC25, QC35, & QC45 Teardown, Easy Part 1 - Take off chasis: passo 2, imagem 1 %32
    • I wont waste time on the disassembly, because it all comes apart easily. Putting it back together is the hard part.
  3. Bose QC25, QC35, & QC45 Teardown, Putting it back together: passo 3, imagem 1 %32 Bose QC25, QC35, & QC45 Teardown, Putting it back together: passo 3, imagem 2 %32 Bose QC25, QC35, & QC45 Teardown, Putting it back together: passo 3, imagem 3 %32
    • I gave up on replacing the headband when I saw how detailed the cabling is to the earpiece - it splits into 4 distinct soldered hair-thin wires which must be reattached. So knowing how sensitive the board must be to poor soldering, I closed it back up.
    • Take note that the black foam 'cup' for the microphone inside the ear cover is too small and the mic just pressed up against it. Dont struggle to get the mic into the foam cup. Close that up first.
  4. Bose QC25, QC35, & QC45 Teardown, The earphone side headband assembly: passo 4, imagem 1 %32 Bose QC25, QC35, & QC45 Teardown, The earphone side headband assembly: passo 4, imagem 2 %32 Bose QC25, QC35, & QC45 Teardown, The earphone side headband assembly: passo 4, imagem 3 %32
    • This grey rotating joint slips into place on both molded sides. The cable is threaded through the headband, this joint, and the earphone outside before you find it soldered onto the motherboard. Just a tip: that think rose-colored clip in the main picture fits onto the band Curved-Side-Down.
  5. Bose QC25, QC35, & QC45 Teardown, Ignore the closed grey lid!: passo 5, imagem 1 %32 Bose QC25, QC35, & QC45 Teardown, Ignore the closed grey lid!: passo 5, imagem 2 %32 Bose QC25, QC35, & QC45 Teardown, Ignore the closed grey lid!: passo 5, imagem 3 %32
    • Inside is only a battery! It takes about 15 minutes of glue scraping to pry this off carefully. Not worth it unless you need to replace the battery.
  6. Bose QC25, QC35, & QC45 Teardown, Headband side clamp /cover: passo 6, imagem 1 %32 Bose QC25, QC35, & QC45 Teardown, Headband side clamp /cover: passo 6, imagem 2 %32 Bose QC25, QC35, & QC45 Teardown, Headband side clamp /cover: passo 6, imagem 3 %32
    • This cover need to both 'bite' with its 'teeth' into the cloth headband and screw together to clamp it onto the metal headband frame. You will adjust this for 5 minutes to get both at the same time.
    • See how the screw holes and the pink 'aligners' fit into the metal frame? You need that lined up while the teeth bite into the cloth part of the headband.
Paul Tast
Membro desde: 09/17/16
984 Reputação
Autoria de 7 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 67
Últimos 30 dias: 355
Ao todo: 5,415
