Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Apple USB Power Adapter, use o nosso manual de serviço.
  1. Apple USB Power Adapter Teardown, Separating the input panel: passo 1, imagem 1 %32 Apple USB Power Adapter Teardown, Separating the input panel: passo 1, imagem 2 %32 Apple USB Power Adapter Teardown, Separating the input panel: passo 1, imagem 3 %32
    • Use a hammer and a small chisel to carefully force the input panel open
    • Clamping the device helps prop the input panel open but, do not pull the panel away from the device forcefully, as there are small wires connected to the device components.
    • Be careful not to force the chisel into the device as you could damage internal components.
  2. Apple USB Power Adapter Teardown, Removing plastic casing: passo 2, imagem 1 %32 Apple USB Power Adapter Teardown, Removing plastic casing: passo 2, imagem 2 %32
    • Use dyke and pliers to cut outside casing to pry open the shell and remove the circuitry.
    • Recommend using hand saw to cut around the plastic.
    • Be careful not to cut forcefully as to prevent the internal components from getting damaged.
  3. Apple USB Power Adapter Teardown, Isolating internal components: passo 3, imagem 1 %32 Apple USB Power Adapter Teardown, Isolating internal components: passo 3, imagem 2 %32 Apple USB Power Adapter Teardown, Isolating internal components: passo 3, imagem 3 %32
    • Isolate the internal electrical components from the casing
    • Recommend unsoldering the wires from the input panel.
    • For help desoldering connections, follow this useful guide on Como soldar e dessoldar contatos.
    • Use caution when soldering. The heated tip may cause damage to the board, the components, or burn you.
  4. Apple USB Power Adapter Teardown, Accessing individual components: passo 4, imagem 1 %32 Apple USB Power Adapter Teardown, Accessing individual components: passo 4, imagem 2 %32 Apple USB Power Adapter Teardown, Accessing individual components: passo 4, imagem 3 %32
    • Unsolder components that connect to the bottom and top circuit boards.
    • Detach the top and bottom circuit boards from the plastic separator.
  5. Apple USB Power Adapter Teardown, Exploration: passo 5, imagem 1 %32 Apple USB Power Adapter Teardown, Exploration: passo 5, imagem 2 %32
    • Observe that once the circuit boards are separated individual components can be accessed.
Juan Gonzalez
Membro desde: 01/24/19
422 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 56
Últimos 30 dias: 227
Ao todo: 21,159
