Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Anova Precision Cooker BT WiFi, use o nosso manual de serviço.
  1. Anova Precision Cooker BT WiFi Teardown, Dismantling the user serviceable parts: passo 1, imagem 1 %32 Anova Precision Cooker BT WiFi Teardown, Dismantling the user serviceable parts: passo 1, imagem 2 %32
    • Grab hold of the upper part of the cooker and the stainless steel skirt
    • Rotate the skirt until it loosens from the slots and pull it off
    • You'll be left with the heating element, the thermometers and the mixing arm visible
  2. Anova Precision Cooker BT WiFi Teardown, Remove the plastic casing: passo 2, imagem 1 %32 Anova Precision Cooker BT WiFi Teardown, Remove the plastic casing: passo 2, imagem 2 %32 Anova Precision Cooker BT WiFi Teardown, Remove the plastic casing: passo 2, imagem 3 %32
    • Locate the two screws that hold the case together. Unscrew them (philips 1)
    • Using relatively much force, insert two fingers beneath the casing and pull it off from the counter part. It is held in place by few plastic clips that will yield with force without breaking (in my case, where I was destroying it)
    • The clips are located relatively close to the upper edge of the casing, if you are interested in shimmying them with a palette knife etc.
    • You are left with the top most cover off, the power cord holding it still in place
  3. Anova Precision Cooker BT WiFi Teardown, Locking tab location: passo 3, imagem 1 %32
    • The plastic locking tabs can be popped open using a 'spud' tool inserted at the fat part of the housing and then slid toward the top of the unit. You can see the tab at the very left of the screen. Green 'spud' tool in the background
  4. Anova Precision Cooker BT WiFi Teardown, Remove the control unit: passo 4, imagem 1 %32 Anova Precision Cooker BT WiFi Teardown, Remove the control unit: passo 4, imagem 2 %32 Anova Precision Cooker BT WiFi Teardown, Remove the control unit: passo 4, imagem 3 %32
    • Remove the control unit by unscrewing the two screws that hold it in place
    • You may then remove the bottom casing as well if interested
    • Notice to remove the control cable before violently showing the control unit aside
    • The fuse is clearly visible next to the power cord. To change it, you need to unsolder it and solder a new one in place
  5. Anova Precision Cooker BT WiFi Teardown, Additinoal dismantling: passo 5, imagem 1 %32 Anova Precision Cooker BT WiFi Teardown, Additinoal dismantling: passo 5, imagem 2 %32 Anova Precision Cooker BT WiFi Teardown, Additinoal dismantling: passo 5, imagem 3 %32
    • The temperature control adjuster can be removed by the two flushed screws
    • To remove the control cable, lift the small plastic shimmer an then pull out the cable
  6. Anova Precision Cooker BT WiFi Teardown, Additional dismantling and reassembly: passo 6, imagem 1 %32 Anova Precision Cooker BT WiFi Teardown, Additional dismantling and reassembly: passo 6, imagem 2 %32
    • The two screws in the bottom of the unit secure the motor in place. removing them loosens the motor. Also remove the propeller from the axel and you can list the engine off
    • When reassembling, note the notch in the circuit board needs to go to the dedicated hole in the casing.
Heikki Otsolampi
Membro desde: 10/10/16
120 Reputação
Autoria de 1 guia
39 comentários
Any idea how to get the very top control unit open?
john - Responder
I think the grey bezel around the display is clipped with plastic clips. I tried to pry it open with a palette knife but didint mange to do it.
Heikki Otsolampi - Responder
My unit has a power fuse located right under the power cord plug at the back of the unit. It unclips and slides out for easy replacement. I the fuse which you show in your photos inside the unit a different fuse than the one I am referring, perhaps an older model. I am curretly experiencing a problem with my unit that I would like very much to resolve. As I'm located in Brazil, it is virtually impossible to get service for my unit. Thaty and the fact that I bought the unit used from a friend compounds the issue. It was however, working perfectly until yesterday when I noticed that the unit is not heating the water. The unit runs and lights up and everything appears to be working fine, but the water is not heating. I have tried cleaning the insides with vinegar and I have tried putting heated water to see if the thermometer is reading the temperature of the water, which it is. After a few minutes however, the temperature begins to drop rather than heat up to my set temperature.
alberguedoslagos - Responder
Does the circulation motor keep running when it stops heating?
Thaddeus -
I have this problem. I can’t heat the water. My circulator spins the whole time. Only problem is it doesn’t heat he water. The upper half of the unit gets hot not the lower.
philip -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 103
Duração total: 15,764
