Ir para o conteúdo principal
« Voltar para Todas as Histórias
The Missing Hard Drive
stephenjoly99 -
MacBook Pro 13" Unibody Early 2011
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
MacBook Pro 13" Unibody Early 2011 Hard Drive Cable Replacement
25 minutos - 1 hora
Moderate
Meu Problema
The problem was that my hard drive was not visible anymore. It wasn't booting properly so I booted to my second HD and it wasn't reading my primary HD (my SSD). Because of this I took it to the apple store to see what they though, took it to canada computers and replaced the SSD and then I saw on the apple support forums that replacing the HD cable fixes the problem.
Minha Solução
So I took to the internet where I found iFixIt and bought the cable from there and managed to fix the problem. The procedure was very easy and my problem was solved. The only hard part was to move my primary SSD from the optical drive caddy back to the primary bay. That took some time.
Meu Conselho
The entire thing was actually very simple, like I mentioned, but I would only recommend doing this is you are 100% sure that the HD cable is the problem. Try to reformat your drives and switch bays to be sure.
Imagem de MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable
$34.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 16
Ao todo: 71
