Ir para o conteúdo principal
« Voltar para Todas as Histórias
iMac HDD Replacement
Joseph Abraham -
iMac Intel 20" EMC 2133 and 2210
Imagem da história
iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
1 hora
Moderate
Meu Problema
Original hard drive went bad, had to replace it.
Minha Solução
Repair went smooth. However, I did forget to attach one cable prior to reassembly. I had to open the unit back up and reattach the video cable. I ended up actually shocking myself because when I reopened the computer, I forgot to unplug the computer.
Also, wasn't able to install the operating system from the DVD drive for some reason. I ended up cloning a drive that was plugged in via USB; I used disk utility.
Meu Conselho
First, never work on an iMac when it is plugged in. There is a possibility of lethal electric shock. Second, in many instances, cloning drives with disk utility is more time effective than reinstalling from recovery disk.
Imagem de 4 TB 3.5" Hard Drive
$172.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 212
