Ir para o conteúdo principal
« Voltar para Todas as Histórias
So far, so good!
bobball -
iPhone 4S
iPhone 4S Battery Replacement
10 - 30 minutos
Moderate
Meu Problema
The battery or charging software in the iPhone 4s became unreliable. It would drop from 30 percent to zero and shut down. The new battery seems to have ended the problem.
Minha Solução
The installation was easy. Other than a couple of minor spooks.
Meu Conselho
Fixing the loose part with tweezers was delicate, and if I recall correctly, I needed to consult other sites to be sure of the orientation of that part. And the ribbon cable from the battery seemed slightly misaligned with the connector once the battery was in place. I connected, then placed the battery.
Imagem de iPhone 4S Battery
iPhone 4S Battery
$16.99
Imagem de Magnetic Project Mat
$19.95
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 11
