Ir para o conteúdo principal
« Voltar para Todas as Histórias
sharp view
haul -
iPhone 5
Imagem da história
iPhone 5 Rear-Facing Camera Replacement
45 minutos - 2 horas
Moderate
Meu Problema
initially i thought the dirt particles inside the iphone 5 camera prevented the focus for getting to work properly, but after an initial genius bar date, it was obvious, the camera has a technical problem. the kind offer to get a out of guarantee special priced phone was not an option.
Minha Solução
smooth and perfect thanks to the advices given by the guide. I took about 2 hours to finish the job, three cigarettes and two coffees. perfect wake up job. It was a pleasure to see the high tec precission of fabrication. respect for this layout.
Meu Conselho
After the battery is removed you have to do a reset of date and time, otherwise the network is not working. so:
set date and time, restart and voila everything back online.
Imagem de iPhone 5 Rear Camera
$49.99
Imagem de Spudger
Spudger
$3.99
Imagem de Phillips #00 Screwdriver
$5.49
Imagem de P2 Pentalobe Screwdriver iPhone
$5.99
Imagem de Suction Handle
Suction Handle
$2.95
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 68
