Ir para o conteúdo principal
« Voltar para Todas as Histórias
Upgrading memory and replacing Hard Drive with Flash Drive.
modima65 -
Mac mini Model A1283
Mac mini Model A1283 Hard Drive Replacement
30 minutos - 2 horas
Moderate
Meu Problema
Slow performance in my MacBook 13'' Early 2009. Run out of disk space.
Minha Solução
Smooth. Simple. Upgrading memory and Hard Drive are among the easiest task you can do in this MacBook model.
Meu Conselho
Before taking out the Hard Drive, I repaired permissions. I used the rubber case included in the kit to be able to use the old HD as external backup, then I restored data from old HD to new Flash Drive using Mavericks and recovery utility included in the OS.
Imagem de PC2-5300 4 GB RAM Chip
$59.99
Adicione um comentário
