Ir para o conteúdo principal
« Voltar para Todas as Histórias
Seamless Macbook Pro Fan install!
nhenderson -
MacBook Pro 15" Unibody Late 2008 and Early 2009
Imagem da história
MacBook Pro 15" Unibody Late 2008 and Early 2009 Right Fan Replacement
Moderate
Meu Problema
My late model 2008 Macbook Pro has been a gem, but all of a sudden the right fan started to give out, the left would be clocked at over 6000rpm while the right was dredging at barely 2000. It was time, after 4 years, to swap the components out.
Minha Solução
It's an easy swap, took 10 minutes only because the screws are so dang small. Fans were in perfect condition, and my computer hasn't been this silent in years. I'd almost forgot what a new MBP is supposed to sound like - nothing! Silence again, my ears rejoice.
Meu Conselho
If you're going to replace one, replace both, it's a cheap swap and you'll save yourself in future woes. If one died, the other is right behind it. Remember to discharge any static electric build up with the metal plate apple installed.
Imagem de MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Left Fan
$39.99
Imagem de MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Right Fan
$39.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 54
