Ir para o conteúdo principal
« Voltar para Todas as Histórias
Baked Apple
chris -
Imagem da história
  • Imagem #1
  • Imagem #2
Meu Problema
Theorized faulty solder connections within ATI graphics chip need to be resoldered.
Minha Solução
Baking it in the oven at 375 for 8 minutes worked perfectly. My laptop works better than before with the new thermal paste and fresh OS install.
Meu Conselho
Remember to shield components you do not want the heat to radiate to. Also, remove the metal clips on the top edge of the logic board before baking in the oven. If you do not, heat will concentrate there (if it's not shielded) and melt the plastic mounting area.
Imagem de Spudger
Spudger
$3.99
Imagem de iFixit Thermal Paste
$24.95
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 68
