Ir para o conteúdo principal
« Voltar para Todas as Histórias
MacBook Pro 2017 battery
Michael C -
MacBook Pro 13" Function Keys 2017
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
MacBook Pro 13" Function Keys 2017 Battery Replacement
2 horas
Moderate
Meu Problema
Original battery did not hold a charge. It was basically unusable for more than 5-8 minutes without being plugged in.
Minha Solução
Was pretty straight forward, the hardest part was removing the battery. The adhesive solvent needed closer to 5 minutes to loosen the adhesive. The tools that came with the battery were excellent.
Meu Conselho
Make sure you use something to keep the screws separated and labeled, I used a towel to prevent the screws from rolling away and labeled with painters tape.
Imagem de MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery
$79.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 8
Ao todo: 8
