Ir para o conteúdo principal
« Voltar para Todas as Histórias
Toyota RAV4 Mirror Control Switch Replacement
FRANCIS -
2019-2024 Toyota RAV-4 Repair
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
2019-2024 Toyota RAV4 Front Windshield Wipers Replacement
3 - 5 minutos
Moderate
Meu Problema
I can move the mirrors now because the mirror control switch is in the bottom position.
Minha Solução
The repair went well. After fixing the mirror control switch, I can move the mirrors again.
Meu Conselho
The repair went well and helped me understand how the mirror control switch works. I learned that the position of the control switch affects whether I can move the mirrors. After putting the switch in the correct bottom position, I was able to move the mirrors again. This repair showed me that a small problem with a control switch can affect an important function of a vehicle. I also learned that testing the function before and after a repair is important to make sure the repair was successful.
Imagem de iFixit Opening Tool
iFixit Opening Tool
$5.95
2 comentários
Great job on that repair!
Theo Grefalda - Responder Compartilhar
Thanks for sharing your repair experience. It's helpful to know that checking the mirror control switch position can solve the problem before replacing any parts. Testing the mirrors again after the fix is a good tip for other RAV4 owners.
albert ainstien - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 51
Ao todo: 88
