Ir para o conteúdo principal
« Voltar para Todas as Histórias
Logithech MX Master 3 thumb rubber repair
Gavriil Kamaris -
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
Meu Problema
There is this common issue with the rubber under your thumb to rip off. I tried a couple of different kind of rubber glue without any success. Finally i used these bike tire repair patches that did the trick. A strip of rubber was completely separated form the device, you can see it in the pictures.
Minha Solução
After a week of use the repair seems to be successful. The patches have a low profile and the touch sense is very similar to the original one.
Meu Conselho
Use some alcohol to rub the surface and clean it from any fat remains.
1 comentário
baton no werking
zahidul islam - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 329
