Ir para o conteúdo principal
« Voltar para Todas as Histórias
Phone repair
Josh Yacktman -
iPhone XR
Imagem da história
  • Imagem #1
  • Imagem #2
iPhone XR Screen Replacement
2 horas
Moderate
Meu Problema
There was a line of broken pixels near the bottom of the screen
Minha Solução
Really well! Don’t underestimate the time you should spend heating the adhesive! Prepare to be waiting a good amount! The picks are the greatest at cutting the adhesive but if you are lifting carefully you won’t need to cut much. Don’t apply to much upward pressure or you can break the screen (though that’s probably not a major concern) or more importantly hurt the sensor display. Make sure you also are careful with the sensor display.
Meu Conselho
Somehow the screen I used worked with True Tone despite me not reprogramming the serial chip or even transferring the old one. Attached is a link to the screen I bought. It was so miraculous even ChatGPT was baffled.
https://www.amazon.com/Fixerman-Replacem...
Imagem de Suction Handle
Suction Handle
$2.95
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 512
