Ir para o conteúdo principal
« Voltar para Todas as Histórias
Lookah Seahorse Pro Plus Repair
finding123 -
Imagem da história
Meu Problema
1. The item did not work well and seems provide less vapors than before
2. The tip was burnt with wax
Minha Solução
1. Take off the core tip,the tip is connected by 510 thread,it is easy to take off.
2. Use brush to remove the burnt wax
3. If your brush can not make the burnt wax clean,please try to use a hard tool to remove it.
4. Be careful,dont destroy the coil
5. Re-install it
Meu Conselho
1. Dont leave the un-burnt wax on the surface of the coil
2. Clean the core every time after use.
3. Keep the coil clean.
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 219
