Ir para o conteúdo principal
« Voltar para Todas as Histórias
iPhone screen replacement
kress -
iPhone 6
Imagem da história
iPhone 6 Screen Replacement
1 hora
Moderate
Meu Problema
Repair cracked screen.
Minha Solução
Part installed perfectly according to instructions on iFixit site. Worked fine after re-assembly except ear speaker (came with screen) sounded gravelly and awful. Took apart and installed speaker from old broken screen (removal instructions also on iFixit, but took some hunting) and now works as good as new. Only flaw was the speaker.
Meu Conselho
Work slowly, particularly if you don't do this regularly. Never become impatient or all is lost. It will work if you are careful.
Carefully think through each step. It's easy to miss one on re-assembly and have to take apart to fix.
Keep track of screw locations and don't mix them up.
Do not over-tighten screws. These are easily stripped. A bit of Lock-tite or similar helps with peace of mind regarding loosening screws.
Imagem de iPhone 6 Screen
iPhone 6 Screen
$44.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 130
