Ir para o conteúdo principal
« Voltar para Todas as Histórias
First time opening a Mac
Ian Schrader -
iMac Intel 27" EMC 2429
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
Installing iMac Intel 27" EMC 2429 Dual Drive Kit (HDD or SSD)
1 hora
Difficult
Meu Problema
The original HDD crashed.
Minha Solução
Very smooth. The how-to was right on the money. I chose to fully remove the logic board and blow out the internals with a can of air while I had it open. Was also able to finally rescue an SD card that had been lost to the Superdrive for a couple of years.
Meu Conselho
Take your time. I used a small tackle box with dividers to keep the screws sorted. I also used some small plastic blocks, about 5" tall, to put between the display and the case while unplugging and plugging in all the connections. I also covered both sides of the glass and display with a clean towel while they were off.
Imagem de iMac Intel 27" (Mid 2011) Dual Hard Drive Kit
$27.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 152
