Meu Problema
Upgrade battery for better speed and performance.
Minha Solução
My son is 14 y.o. and has done many display replacements since he is careless and drops his phones often. This was his first battery upgrade and everything went well until he had to use the credit card trick to remove the battery and adhesive strips. He finally ended up using the .009E guitar string trick. But it took longer to pry it out then the rest of the procedure from start to finish.
Meu Conselho
Try prying adhesive strips very, very, gently around the corners.
0 comentários
