Ir para o conteúdo principal
« Voltar para Todas as Histórias
First time user
Dennis Keith -
iPhone 5s
Imagem da história
How to replace the battery in your iPhone 5s
40 minutos
Moderate
Meu Problema
I needed to Charge the phone about noon or 1 o’clock every day and then again at five or six
Minha Solução
The video was helpful to get an orientation and then I went to the step-by-step process. The only issue I had was removal of the tape holding the battery in place one of them came out easily the other one broke off and it took some work to get it out.
Meu Conselho
Based on my experience I would say there are two things to be careful about one is to be sure you have a clean workspace where the little screws can’t get blown around or lost. Also do not twist the tape when you pull it out and when you need to work it around the battery be very careful and use some soft edged tools to help you get it around the corners.
Imagem de iPhone 5s Battery
iPhone 5s Battery
$29.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 66
