Ir para o conteúdo principal
« Voltar para Todas as Histórias
External Speaker Replacement
David Sikole -
LG G4
Imagem da história
LG G4 Speaker Replacement
5 minutos
Very easy
Meu Problema
The external speaker no longer worked.
Minha Solução
Phone off. Pop the back cover starting at the charging port. It came off easy with my fingers. Take out the battery. Take out all the screws. The bottom assembly, external speaker, slides out. Discard the old part and slide in the part. Put the screws back in. Battery in. Cover on. Repair done.
Meu Conselho
Small phillilps screw driver found with eye glass repair kits was my tool. Since the screws are so small, taking the screws out on a tray would be helpful. Also, be patiet when putting the screws back in
1 comentário
Good job,
Need wholesale LCD screen? https://txlcd.com/
txlcdsupplier - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 89
