Ir para o conteúdo principal
« Voltar para Todas as Histórias
Wonky battery
tim -
MacBook Pro 13" Unibody Mid 2010
Imagem da história
MacBook Pro 13" Unibody Mid 2010 Battery Replacement
10 minutos
Easy
Meu Problema
Bought a refurbished MacBook Pro off of Amazon for my son to take to college. Periodically it would go into low power mode even when the power cord was plugged in. The battery would indicate it wasn't plugged in sometimes. Jiggle the thing and it would be ok. Opened it up to verify the connection was solid and decided to try a new battery and cross my fingers since there is no warranty on the computer.
Minha Solução
Ridiculously easy to replace the battery in these things, well that is as long as you have the right Tri-point screwdriver, which I do in my iFixit 64 Bit driver kit!
Meu Conselho
Why replace when you can repair, save a ton of money, and get great satisfaction when all your friends look upon you with awe at your repair prowess?!
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 130
