Ir para o conteúdo principal
« Voltar para Todas as Histórias
iPad 4 front panel replacement
venales -
iPad 4 Wi-Fi
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
iPad 4 Wi-Fi Front Panel Replacement
1 hora
Difficult
Meu Problema
iPad 4 front panel was broken.
Minha Solução
First, I followed the iPad 4 front panel replacement guide in the iFixit.com. My method was not different largely.
Meu Conselho
1. I used hot wind gun instead of the iOpener. Then you can blow the panel about 15 seconds for loosen the adhesive film.
2. When you lift the front panel, you must care of the home button flex cable. It is so weak and can be tear easily!!
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 9
Últimos 30 dias: 14
Ao todo: 187
