Ir para o conteúdo principal
« Voltar para Todas as Histórias
Hard Drive to SSD Upgrade
Brandon Dusseau -
iMac Intel 27" EMC 2309 and 2374
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement
15 minutos
Easy
Meu Problema
The hard drive was failing so I decided to upgrade to an SSD.
Minha Solução
The installation was pretty easy, but required some additional parts to keep the machine happy.
Meu Conselho
For replacing a hard drive with an SSD, an adapter bracket needs to be used, in addition to a third party thermal sensor to keep the fans from running on high all the time after installation (as the original hard drive contains an Apple sensor that the iMac expects to be present).
Make sure to have already created a bootable OS X installation disk or be able to boot to the recovery partition on the original drive using an external adapter. iMacs prior to 2011 do not have Internet recovery and will be unable to boot unless an installation media is present.
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 414
