Ir para o conteúdo principal
« Voltar para Todas as Histórias
Successfully replaced Hard Drive cable
gdvail -
MacBook Pro 13" Unibody Early 2011
Imagem da história
MacBook Pro 13" Unibody Early 2011 Hard Drive Cable Replacement
25 minutos - 1 hora
Moderate
Meu Problema
When I got the dreaded "flashing ?", I thought it was the Hard Drive and replaced the drive. That didn't fix the problem, so I assumed it was most likely the cable and ordered it from iFixit. To make the install a bit easier, I got the cable with the IR sensor/sleep LED bracket already attached. I also added electrical tape over and under the new cable to protect it.
Minha Solução
The repair was easy and went very well, and best of all, it fixed the problem. I booted the computer up in OS X Internet Recovery mode and restored the system. It's working fine.
Meu Conselho
I'm a 73-year-old women. If I can do this, anyone can. Read the instructions, watch the videos, and just do it
Imagem de Phillips #00 Screwdriver
$5.49
Imagem de MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable
$34.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 7
Ao todo: 77
