Ir para o conteúdo principal
« Voltar para Todas as Histórias
The unexpected release on the lowercase
gveldman -
MacBook Unibody Model A1342
Imagem da história
MacBook Unibody Model A1342 Lower Case Replacement
30 segundos - 5 minutos
Easy
Meu Problema
A few weeks ago the rubber coating released it self, caused by the heat, from the lowercase of our Macbook, end 2009 version. Because the Apple replacement program was not applied on this Macbook, I decided to repair it my self. The Macbook is in perfect state, including 4GB memory and running Yosemite, 10.10 OS X.
Minha Solução
The repair was easy to do. The order (the lowercase and screws) from iFixit arrived very quickly, within four days to the Netherlands, well done! The Macbook lost some screws by the time, so I replaced them as well.
Meu Conselho
Use a proper screw-tool that fits exactly to the small screws on the lowercase. I placed small feet, 3 mm in height, on each corner on the lowercase. So the heat can flow under the lowercase in the air.
Imagem de MacBook Unibody (A1342) Lower Case
$39.99
Imagem de MacBook Unibody (A1342) Lower Case Screws
$14.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Ao todo: 217
