MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
  • MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
US$219,99
US$219,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
Replace your LCD!
Glossy and matte finish LCDs are interchangeable, you can install either type in your MacBook Pro 17", regardless of the original LCD panel type
IMPORTANT: This LCD is only compatible with MacBook Pro 17" laptops that are model A1261 and shipped with LED displays and a 1920x1200 resolution. Although visually identical, this part will not work in the Low-Res CCFL 1680x1050 Models. The LCD for the low-res model can be found here: MacBook Pro 17" (Model A1151/A1212/A1229/A1261) LCD Panel.
Compatibilidade
Compatibilidade
  • 2.5 or 2.6 GHz (Model A1261) 17" MacBook Pros with 1920x1200 resolution
Especificações
Especificações
Size:
17"
Resolution:
1920x1200
Compatibilidade
Histórias de Reparos
Avatar do usuário
Meu Problema
LCD was bad on a Macbook Pro A1261, ordered new screen.
Minha Solução
Took everything apart only to realize I had ordered the wrong screen. Take note technicians, check your connectors on new parts before breaking everything down. And read everything about the part you are ordering carefully.
Meu Conselho
iFixit team respond . . .
Avatar do usuário
Meu Problema
in quick succession I broke the LCD on the 17" Macbook Pro due to sloppy handling, and I shattered the glass front on my iPhone 5.
Both were not yet at the end of their life/usefulness so I decided to fix both myself.
Minha Solução
things went pretty well. Finished both repairs in about 3 hours (while watching . . .
Avatar do usuário
Meu Problema
My 1 year old son had smashed my MacBook Pro screen and it was damaged for more then a year. I inquired at the local Apple Store and was shocked to know that the LED display would cost me around 1000$, it was so expensive that I thought I would never be able to repair it, until ifixit stepped in my . . .
Avatar do usuário
Meu Problema
Broken LCD on my macbook pro
Minha Solução
Ordered part to fix. But it was damaged:( so i called got a replacement. Great CS by the way. Well.. I got ancy and started to take apart the laptop and found out that i ordered the wrong part.. Called back and the 1st replacement was already sent. So i ordered the right . . .
Mostrar mais
