Ir para o conteúdo principal
uAttend bn6000 Fingerprint Replacement
O que você precisa
  1. uAttend bn6000 Fingerprint Replacement, Disassembly: passo 1, imagem 1 %32
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    Pergunte ao FixBot
    Comentar
  2. uAttend bn6000 Fingerprint Replacement: passo 2, imagem 1 %32
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
    Pergunte ao FixBot
    Comentar
  3. uAttend bn6000 Fingerprint Replacement, Fingerprint: passo 3, imagem 1 %32 uAttend bn6000 Fingerprint Replacement, Fingerprint: passo 3, imagem 2 %32 uAttend bn6000 Fingerprint Replacement, Fingerprint: passo 3, imagem 3 %32
    • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
    Pergunte ao FixBot
    Comentar
  4. uAttend bn6000 Fingerprint Replacement: passo 4, imagem 1 %32 uAttend bn6000 Fingerprint Replacement: passo 4, imagem 2 %32 uAttend bn6000 Fingerprint Replacement: passo 4, imagem 3 %32
    • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble , follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 35
Ao todo: 923
