Introdução
If your ionvac SmartClean V2 fails to power on, or the power button is loose, stuck, or broken, it may be a sign that the button needs to be replaced. In order to complete this process, you must first disassemble the top shell that houses the button. This guide will show you how to remove the power button without causing any damage.
This is a quick and easy replacement, and you will need a Phillips #2 (PH2) screwdriver and a Jimmy tool (or another prying tool) to complete it. Remember to remove and reinstall all parts gently.
O que você precisa
Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
Flip the frame upside down so that the inside faces upwards.
Locate the 2 screws connecting the power button to the frame.
