Ir para o conteúdo principal
ionvac SmartClean V2 Main Brush Replacement
    1. ionvac SmartClean V2 Main Brush Replacement, Main Brush: passo 1, imagem 1 %32
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Flip your ionvac upside down so the wheels are pointed upwards and the side brushes are furthest from you.
      • Place your thumbs on the two release tabs of the main brush cover (brush guard) and push the tabs open.
      • Remove the brush guard.
      Pergunte ao FixBot
      Comentar
    2. ionvac SmartClean V2 Main Brush Replacement: passo 2, imagem 1 %32 ionvac SmartClean V2 Main Brush Replacement: passo 2, imagem 2 %32
      • Hold the brush on both ends.
      • Pull the right side out first, releasing it from the ionvac.
      • Remove the entire brush from the ionvac.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 31
Ao todo: 671
