Ir para o conteúdo principal
ionvac SmartClean V2 Battery Replacement
O que você precisa
    1. ionvac SmartClean V2 Battery Replacement, Battery: passo 1, imagem 1 %32
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. A magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac upside down so the wheels are pointed upwards and the side brushes are furthest from you.
      Pergunte ao FixBot
      Comentar
    2. ionvac SmartClean V2 Battery Replacement: passo 2, imagem 1 %32 ionvac SmartClean V2 Battery Replacement: passo 2, imagem 2 %32
      • Remove the 2 screws that secure the battery door.
      • Lift the battery door to reveal the lithium ion battery.
      • If the battery cover is stuck, use a Jimmy or another prying tool to pry it off.
      Pergunte ao FixBot
      Comentar
    3. ionvac SmartClean V2 Battery Replacement: passo 3, imagem 1 %32 ionvac SmartClean V2 Battery Replacement: passo 3, imagem 2 %32
      • Disconnect the battery by squeezing down on the cream-colored tabs of the battery connectors and pulling them apart.
      • Caution: Be careful when removing the connector, as the part can break if too much force is used.
      • When reinstalling the battery, remember to place it in your ionvac with the white strip facing up. If the battery has two flaps, ensure the flaps are facing up before screwing in the battery door.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
2Comentários do guia
need instructions for installation of battery in TZUMI ion vac smart clean robo vac V4
Eileen Meyer - Responder Compartilhar
need instructions for installation of battery in TZUMI ionvac smart clean robovac V4
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 98
Ao todo: 3,665
