Ir para o conteúdo principal
iodyne Pro Data SSD Module Replacement
O que você precisa
    1. iodyne Pro Data SSD Module Replacement, Remove Service Panel Screws: passo 1, imagem 1 %32
      Ferramenta utilizada neste passo:
      Anti-Static Wrist Strap
      $7.95
      • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
      • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
      Pergunte ao FixBot
      Comentar
    2. iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: passo 2, imagem 1 %32 iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: passo 2, imagem 2 %32 iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: passo 2, imagem 3 %32
      • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
      • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
      Pergunte ao FixBot
      Comentar
    1. iodyne Pro Data SSD Module Replacement, Unfasten SSD module: passo 3, imagem 1 %32 iodyne Pro Data SSD Module Replacement, Unfasten SSD module: passo 3, imagem 2 %32
      • Identify the SSD module for replacement and note its retaining screw on the chassis perimeter.
      • Unfasten and remove the retention screw for the SSD module to be replaced using a #2 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. iodyne Pro Data SSD Module Replacement, Remove SSD module: passo 4, imagem 1 %32 iodyne Pro Data SSD Module Replacement, Remove SSD module: passo 4, imagem 2 %32 iodyne Pro Data SSD Module Replacement, Remove SSD module: passo 4, imagem 3 %32
      • Lift the outer edge of the SSD module to a 15° angle from the motherboard.
      • Pull the SSD module up and away from its port to remove.
      • Insert the new SSD module at the same angle, then lower it into position and fasten its retention screw.
      Pergunte ao FixBot
      Comentar
    3. iodyne Pro Data SSD Module Replacement, Validate repair: passo 5, imagem 1 %32
      • After reassembling the chassis by following the steps in this guide in reverse, verify that the new SSD module is recognized and healthy by launching iodyne from the Applications folder and navigating to the Status tab.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order, then validate that the replacement SSD module is healthy by launching iodyne.app and navigating to the Status tab.
Uma outra pessoa concluiu este guia.
iodyne
Membro desde: 01/01/22
462 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 607
